Surround sound with headphones
Solved by BrightCandle,
4 hours ago, Alesek said:if I boost those frequencies, arent my ears gonna explode when I use AK47 as the shot sound is also quite low and they increased the volume?
it is showing as headphones, not 7.1. I thought that it was the best way to set it up, Ill try it one later when I get home. I tried Dolby headphone but it is even worse
To the OS it needs to show 7.1 to get dolby headphone working, then in the Xonar control panel you have the output as headphones and DH on.
