PC reboots when its under heavy load, no BSOD!
My PC reboots when its under heavy load, and it does not show a BSOD.
I tested the PC with IntelBurnTest, and nothing happend.
But I then tested it with FurMark and it reboots after a couple of minutes (first time 13min, second time around 7min). I then disable my SLI and had it running for 30 minutes and no reboot.
So could the problem be my PSU, or is it one of my GPU's?
PC Specs:
PSU: Cooler Master G750M
GPU: 2x MSI GTX 970
CPU: i7 4790K
RAM: 16GB
SSHD: Seagate Desktop SSHD 1TB
Motherboard: MSI Z97-Gaming 5
Most probably a PSU problem, since it doesn't BSOD.
Might also be a temperature problem, but you can find that out very easy:
Does it automatically reboot?
Yes -> most probably the PSU
No -> might be a temperature problem
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems doing CPU installation." -Linus
delid i7-3770k @ 4.2Ghz @ 1.265V | EVGA z77 FTW | GTX 680 2way-SLI | 16GB Corsair Dominator Platinum @ 1866MHz | 240GB SSD RAID 0 | Full Custom Water Loop with two 360mm radiators  -> live temps <-
It reboots by itself, and I made the fans spin on 100% so the temp was under 80 at all times.
Well then it must be the PSU.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
Okay, any recommendations on a PSU for my system.
Maybe Seasonic M12II, EVGA supernova G2 or similar.
Desktop
LAPTOP
Thanks mate
