How rare is it to get a faulty power supply out of the box?
Solved by AresKrieger,
3 minutes ago, Lollo said:I wish I could have those odds at getting good things from unboxings from any game.
Thanks though, I'm glad it was as rare as I thought. If I were to send it back to newegg should I just include power supply or send everything back?
Well it is rare but 1 out of 50 is still significant (and as I said it can be higher if a cheaper product 1/20 for a lot of items and much much higher for really cheap crap)
And yes you send everything, the packaging any included info etc, if it came in the box send it back with the box
