Help with Optic Fibre
1 hour ago, yoyDIY said:Thank you for all of you to help me this way. The reason why I thought of it is because of the following:
The internet comes from an router in front of the house and the bedrooms are at the back-so I thought I can get more speed redundancy by making all the communication between the computers faster by making the connection to the Internet separate and a switch for the communication with the pc's at the back of the house
You can still do what you plan to do just use a copper Cat 6a cable rather than a fibre cable. Cat 6a even supports 10Gb over 100m. You use fibre when you need to do a length of 300m or 500m, you can do even longer with single mode fibre (10km-80km).
Also the 4 cables between the switch and router won't give you any extra speed, network or internet, only redundancy and you can do that with just 2. This is of course if the router even supports link aggregation/teaming.
You need to think of multiple connections a little bit differently, a single device can only use 1 path so having 2 gives no benefit for that single device. The next thing to think about is do you need more bandwidth than a single path can give, for internet the answer is no.
Where you would be better off is 2 cables between the managed switches so if 2 separate computers were doing large file transfers to 2 different devices on the other switch each would get a 1Gb path each. Or if two devices on the opposite switch to the FTP were doing file copies they would get a 1Gb path each all the way through to the FTP server.
Edit: Also even with the planned changes you won't actually notice any speed increase, it is a nicer setup networking wise though.
