My sound in games is reversed
AnTicXz
The audio from the left is coming form the right speaker and the other way around Help!/?
You're wearing your hedsett backwards?
no...
1 minute ago, CODboyX said:
no...
Could you tell us some more information?
Are you using a headset?
If not, are you using a monitors speakers? are you using a hi-fi's speakers? Please provide a bit more information so i can try and help you.
Kind regards,
Matt
CASE: NZXT H440 Black
MOBO: ASUS Maximus VIII Hero
CPU: Intel Core i7 6700k @ 4.2GHz
GPU: Nvidia GeForce GTX 1080 FE
RAM: Corsair Dominator Platinum -- 16Gb -- DDR4 - @ 2400Mhz
PSU: Corsair RM1000
HDD 1: WD Blue 1TB
HDD 2: WD Blue 500GB
SSD 1: Sandisk Plus 120GB SSD
SSD 2: Toshiba Q300 120GB SSD
CPU Cooler: Corsair H100i V2
3 minutes ago, CODboyX said:
no...
You sure? Most headsets have the mic of the left side.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
That's what i thought at first. Though there are a few cases where earphones and headsets from low brands are cheaply made, and don't follow the standard we expect from our audio solutions. so it's possible he's using a cheap headset where they've flipped the audio, from left to right, and vice verse. It would be convenient if he provided more information, like branding, weather the issue occurs in games only *A good way to test this is to use softwares like razer surround, or your headset brands software, to configure your audios "Surround" and check if it's flipped there.*, what audio solution he is using and more.
Most headphones have their wires on the left side, along side a microphone. I do hope he provides more information to us so we can help him.
My apologies if i assumed your gender incorrectly, i use him/he, because it's easier to type while i'm tired.
Kind regards, and have a great night,
Matt
PSU: Corsair RM1000
HDD 1: WD Blue 1TB
Try opening the playback devices, selecting you're headphones, then going to the advance tab and changing the setting to a different format. You can change it back afterward, all that's required is that it's changed. I had that issue on my old usb headset and I think that's how I would go about fixing it.
Edit: I should probably also mention that this was just a temporary fix for me.
To be honest, is it that much of a problem?
Try adjusting it in Windows Playback Devices
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
u drunk mate? How would you like it if enemies sounded like they were coming from the opposite direction that they actually were?
