CPU overheating error - AIO water cooler now scrap?
Tim Q
So just this morning my computer (Specs are in my signature and BIOS ver. is 2501) out of the blue went apeshit with the CPU fans and ramped them up to max before blacking out on me.
After a bit of fiddling it booted me back into the BIOS where it turned out the the 4790K was idling at around 90C.
I removed the Nepton, cleaned up the paste, reseated the CPU and put it all back together with new MX-4 paste. No luck, 90C idle.
I then changed it out for the stock Intel cooler and now it's been sitting comfortably in the mid 30s for a while now (it's still running as I type this).
While I'm pretty sure the AIO is junk now, I just wanted to confirm - there's no saving it and I should just swap it out for a beefy air cooler?
1st Build: Intel Core i7 4790K, Cooler Master Nepton 280L, ASUS Z97 Pro Wi-Fi AC, Kingston HyperX Fury Black 2 x 8GB 1866MHz, Gigabyte G1 Gaming GTX 970, Crucial MX100 256GB, Seagate Desktop HDD 3TB, Seasonic SS760XP2, Phanteks Enthoo Luxe, Windows 10 Pro x64
Peripherals:  Audio Technica ATH-M50s + Antlion ModMic 4.0, Samsung S24D590L, Corsair M65 RGB
Other Devices: Lenovo ThinkPad Yoga, ASUS Vivotab Note 8.
Is the pump plugged in? If it is it sounds like the pump is dead. Have you got the pump header set to max in order to get liquid flowing and to clear a possible blockage?
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
I've checked it out - the header that the pump was connected to returned as N/A - not picked up by the motherboard at all. Tried different headers, still got nothing.
I could hear the pump slowing down after turning off the machine.
After I took out the cooler I did notice that the block and lower half of the tubing were warm, but the radiator and upper tubing were stone cold.
I'm thinking a warranty claim might be needed here - documents say it should be good for five years.
Damn that's unlucky. I recommend just getting your money back and going for a large air cooler. I know it can look a bit funny but you don't have to worry about bad pumps or leaks and in some cases the air cooler can perform better.
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
