Put Silent Wings 2 PWM on Amd Fx 4100 Stock cooler
IExPeNschI
Hello guys
I would like to put a Silent wings 2 pwm on the stock cooler of my amd fx 4100.
Which fan size i should use and is it even possible?
3 minutes ago, IExPeNschI said:
Hello guys
just get a different cooler, the stock cooler is crap
buy a 212 evo and then you can use a 120mm fan
12 minutes ago, Enderman said:
buy a 212 evo
I would say the Cryorig H7 would look/preform better B4B but yea you are right
The H7 does not perform better than the Hyper 212, but it looks a heck of a lot better.
I would say the performance is almost identical, but it does look a lot better
I have both and the H7 is about 8-12oc hotter than the Hyper 212 Evo
You may have improperly mounted it in that case. They should perform nearly the same.
Identical performance for more $$, even if the aesthetic is (subjectively) better.
