Noctua low noise adapters help
Solved by WoodenMarker,
6 hours ago, azorahai said:I guess that is true. Though I am sure that the LNA does more to dampen sound than simply reduce the max rpm....otherwise why include LNAs on PWM fans?
LNA only lowers the fan speed. They're included in case the user doesn't have a method of lowering the fan speed.
IhateAMDDRIVERS ·
Posted in Troubleshooting0 -
SashaSanguine ·
Posted in General Discussion2 -
3
Redsin ·
Posted in Graphics Cards2 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards12 -
1
2
1
3
2
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
