GTX 1080 volt issues past 1.25v
Lays
4 minutes ago, IcEWoLF said:
A stock 1080 is much better than the 980 gtx ti overclocked, if you are thinking about getting a plain 980 don't, get the 1070 which is very good.
Thanks for the quick reply!
probs will get the 1070 when the AIBs release. really want a 1080 but its like £600ish :(
The OC 'ability of the 980ti is only really super relevant on LN2 or Dice (compared to the 1080). Outside of that, the stock 1080 is right on par with a OC'd 980ti although the 980ti is drawing like 100W more.
Honestly 1070 vs 980ti is a straight win for the 980ti right now (again ignoring power differences, which is admittedly a big deal).
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
3 minutes ago, Curufinwe_wins said:
The OC 'ability of the 980ti is only really super relevant on LN2 or Dice. Outside of that, the stock 1080 is right on par with a OC'd 980ti although the 980ti is drawing like 100W more.
considering a 1070 and a used 980ti is going to be round the same here round £350, i think its just more reason to save up. *sigh*,
also, i guess the 1070 would also have this 1.25v limit as well right?
Yeah there is a very big chance that it will also have the 1.25v limet
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
This is exactly why I'm waiting to see if I should even bother getting a 1080 right now.
Good news boys, LN2 2500 mhz on a HOF 1080 at 1.39v, seems they found the secret sauce somewhere to get voltage working properly.
Still slower than the top 980 ti's on LN2, but still good nonetheless!
 The score is about even with a ~2025 mhz 980 ti on Ln2.  The top 980 ti are capable of ~2100-2220 mhz at 1.75-1.85v i believe.  So the 1080 still needs to get a bit faster to catch up.
13323253_1220103258030438_40171205393994
But on water, for every day usage, like most of us here do, the 1080 is faster than the 980ti.  Got it.
CPU: Ryzen 1600X @ 4.15ghz  MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200
GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2  SSD: 512GB Samsung 950 PRO
HD: 2 x 1TB WD Black in RAID 0  Cooling: Custom cooling loop on CPU and GPU  OS: Windows 10
yessir, 24/7 use the 1080 is faster. On Ln2 / dry ice, 980 ti should be faster.  (as of right now)
Good stuff @Lays I think they'll figure it all out as time goes on. Here's hoping they break the 3GHz barrier. :)
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
Damn Lays you beat me to it. Was just gonna hop back to this thread and post some updates on the status of things.  Anyway this is what TiN had to say.
Voltage scaling and “1.25V limit”
There were some rumors spreading wildly these days regarding “1.25V limitation” or whatever on modified GTX 1080 cards, which requires here few words to explain.
Hardware itself is well capable of getting to that and above voltage output for GPU core, but GP104 chip itself now more sensitive to voltage, than even previous Maxwell generation. Part of it due to thinner physical process, other part due to challenges removing heat from all those tightly packed 7.2B transistors quick enough from 21% less surface area. Those overclockers who did 2200+ MHz on GTX 980 Ti’s are well aware of all things required to achieve those high clocks. Same principle applies to Pascal generation. So if you can manage to keep GPU cooled well and have good voltage delivery to it, you indeed can push higher voltages. Cards cooled by liquid nitrogen during this guide testwork were able to run 1.35-1.4V, reaching speeds over 2500 MHz.
Fact that GTX 1080’s capable of reaching 2.1GHz on aircooling without any modifications confuse lot of people, making them to think that these chips can overclock well past 3GHz on liquid nitrogen cooling. But it’s still silicon, with similar architecture, so reality is bit sour. Yes, it allow to get good performance without extreme cooling, but hides the fact that LN2-cooled 980Ti is still much faster than overclocked GTX 1080 due to more shader cores and better CPC performance.
This also brings and answer to the question if overvolting can help OC on aircooling or watercooling. It does not help, due to thermal, which get only worse. Higher temperature render stability and performance decrease. GPU literally overheats and cannot run high frequency anymore, even though temperature is below specified maximum temperature. So just like in 980/980Ti/TitanX case, over-voltage is not recommended, as it gains no performance improvement.
As usual, any feedback and questions are appreciated. Feel free to share link to this guide, but keep links and references intact, as guide likely to be updated in future.
I still think there's a chance that'll change with driver updates, and better hardware, but.....we'll see.  /shrug
I've an idea of why this might be. Take a look at http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1070/4.html
They've included an all new voltage regulator chip. Perhaps that one caps at 1.25v
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
