Need help doing clean install of Win 10
By
djdelarosa25
in Windows
in Windows
Solved by manikyath,
the moment win10 has been on the computer (as in, when you did the upgrade frim 7/8.1->10) you can clean install as much as you want without ever needing a key.
should say, if you do the upgrade, its best to also clean install afterwards, the upgrade is hilareously buggy.
Nexxus ·
Posted in Programs, Apps and Websites2 -
ds5018 ·
Posted in Troubleshooting0 -
1
Muzzy2002 ·
Posted in New Builds and Planning2 -
modern_officer ·
Posted in General Discussion5 -
3
Coding2bLazy ·
Posted in Troubleshooting8 -
Thezgamer75 ·
Posted in Troubleshooting1 -
6
9
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
