Keep fans running 24/7 even while PC is off?
Solved by 0x1e,
When my PC is off I put a piece of cloth over the top to cover the fans.
This will stop all the dust getting in when it's off.
Dust filters don't stop all the dust getting into the case, even if it's the only intakes and you have plenty of positive air pressure. Very fine dust will still make its way in.
Rummers ·
a7med ·
4
1
moondogkill ·
Posted in Cooling1 -
1
snaphappy7530 ·
Posted in Troubleshooting4 -
JanS0lo ·
Posted in Troubleshooting3 -
3
CB1608 ·
Posted in Troubleshooting1
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
