Hi, I'm planning on upgrading my monitor in the near future and want to get a 1440p 144hz monitor with an ips panel. So far, I had been looking primarily at gsync displays but I realized I don't necessarily need gsync as long as my hardware can push the fps high enough (I plan on purchasing a gtx 1070 or 1080 once they release). So, what monitors do you recommend? I'd be fine with a freesync display even though I couldn't use it, the cheaper cost is a great incentive. I'd prefer a curved monitor, but from what I've seen, most of those are crazy expensive. Thanks!
https://linustechtips.com/topic/596936-1440p-144hz-monitor-suggestions/
What do you consider "cheap"? It's different for every person.
You also didn't say what size monitor you're after.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
As far as pricing goes, I'm looking for something relatively cheaper to say the Asus pg279q (around $750-$800 us). I know that and the Acer one are two great options for 1440p monitors but I couldn't find much else besides the two.  Most likely I will end up with them,  but I want to be able to consider all my options.
