1 minute ago, LinusTechTips4Life said:
What parts will i choose first e.g Case, Motherboard
pretty much what you had in mind. Motherboard and case and the two thing you gotta pick first.
Get a case that is compatible with your motherboard (mATX, ATX, ATX-E) then pick the rest along the way.
no you choose the HDD first. jk
What are you looking for?
You start with the CPU.
Then you get a motherboard that's compatible with it.
Then you get a case compatible with the motherboard, if you don't find one, change the motherboard and retry...
Continue on from there.
CPU: AMD Ryzen 3700x / GPU: Asus Radeon RX 6750XT OC 12GB / RAM: Corsair Vengeance LPX 2x8GB DDR4-3200
MOBO: MSI B450m Gaming Plus / NVME: Corsair MP510 240GB / Case: TT Core v21 / PSU: Seasonic 750W / OS: Win 10 Pro
1. CPU
2. Motherboard
3. CPU cooler, in such a way that it does not block RAM slots
4. Case
5. Compatible Ram
6. Go to step 3 and see if there are RAM clearance issues
7. Doesnt matter from here really
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
From conventional thought, you start with CPU and build from there.  When I was going to University of Phoenix, my PC hardware and maintenance professor said you should actually start with motherboard and build around that.
Her reasoning is that it didn't matter what CPU, RAM, etc you got if they can't connect to the MOBO.
though after choosing those two, choose ram and CPU cooler (if you plan on using an aftermarket one).  Then storage, case.  Here's where I get controversial (depending on who you talk to). Get the power supply that can handle most anything, but be enough for the weakest budget build to something higher end.  This way you'll have all your components picked out, and whatever is left of your budget, spend on the most powerful GPU you can get.
Currently focusing on my video game collection.
It doesn't matter what you play games on, just play good games you enjoy.
