IPod touch 5 not working Plz Help
Go to solution Solved by sirtoby,
Have you force restarted it? If that didn't help, then head to the Apple store. Apples support is amazing when you're still in warranty (which you are).
Did you try force turning it off by holding the power button and turning it back on?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
