Hi forum,
i just bought a used EVGA 750TI FTW (saw it working when i bought it.)
There is a 6-pin connecter on the card, so i need a new PSU for it.
I saw a comment on youtube, that somebody uses it without a 6-pin connecter, so is it possible for me to run it without the 6-pin connecter?
I just wish to check that its working properly. I will get a new PSU from my friend in 10 hours.
If it needs more power than my current PSU gives, will i then just get a warning, or no boot, or will i ruin anything?
Thx.
Yes, the username is cringe.
PCIe slots can only provide a maximum of 75W of power. If the card doesn't get enough power, it'll complain about it and maybe display it on the screen for you(mostly dealing with the lack of a supplemental connector).
I dont think that my current PSU has enough watt to run it.
I just wished to insure that it was running.
But i will just wait until the morning (10 hours from now)
and pick a new psu up from my friend.
Don't run it without the 6 pin, it can burn your motherboard traces or just don't work, these connectors are especially made for delivering power that motherboard can't. Just wait these 10 hours, make yourself some tea in the meantime.
No single GPU card on the market needs more than 250 watts, your is lower end so I think you could run it with 400 watt PSU as well.
But if your PSU is not good enough it all depends on luck and PSU brand. No-names can even burn your house, break everything in your PC or just do nothing. Branded PSUs from good series like Seasonic aren't likely to fail tragically. But if your current one doesn't have 6 pin, it's probably old, no-name or doesn't provide enough power.
I need S340. But more Define S'ish
12 minutes ago, L0gic said:
snip
You can use a 2 molex to 6 pin adapter for the additional power. Something like this
But please make sure the PSU can carry the card's power consumption (750 Tis don't consume more than 80Ws so you should be fine) and as soon as you have some money to upgrade the power supply, do it. You'll find good quality PSUs starting at €43 ish and you can ask for a recommendation over at our thread :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
you will get no boot with beep codes pointing to insufficient VGA power
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
