How to properly clean a CPU Heatsink
Dive5885
My issues here is I managed to clean the outside of the heatsink but inside of it there is dust I can't remove because I can't stick anything within the heatsink fins to clean it.
So what would be a proper way to clean it?
Can I rinse it with water? Power wash? Maybe use a leaf blower?
Let me know what ideas you guys have and what would work!
Thanks!!
Intel Core I7 7820X | Asus Rampage VI | Gigabyte RX 580 XTR | 32GB Crucial Ballistix | NZXT Kraken X62
ADATA XPG 256GB PCIe| Cosmos C700P CM | Lepa MaxPlatinum 1050W
If you take the fan (and any other electronic components off), its fine to rinse the heatsink with water. Make sure to let it completely dry before putting it back together.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
take off the fans and any electronics (like LED and what not)
then dump it into a bucket of water and swirl it around (dont break/bend the heatpipes or fins while doing so)
and then dry it with hair dryer (dry it completely to prevent corrosion issues)
-sigh- feeling like I'm being too negative lately
Thanks!!
put it in water then dry it
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
14 minutes ago, GreezyJeezy said:
just give it a bath and dry it 100% before putting it back on
Alright cool!
I'll give it a wash and then dry it with a hair dryer or maybe use the leaf blower.
remove the fan any other electronics attached to it
prepare some soapy water - give it a bath; rinse with fresh water and dry
do you have a dish washer? give it a bath
Yes I do have a dish washer. Would putting it in the dish washer be a better idea than hand washing it?
you can't get in between the fins, and there's a film of dust stuck in there - the dishwasher will do a better job
6 minutes ago, Dive5885 said:
Alright cool!
hair dryer is better
because it'll heat up the entire thing causing water in creeks and crevices to evaporate away
Yeah that makes sense.
I was thinking the leaf blower would of been better because its more powerful
Should I also let the dish washer dry it using the heat dry or should I just dry it myself after the wash?
I don't even want to imagine the look on my wife's face if she opened up the dishwasher and pulled out a heatsink lol
Aerocool DS are the best fans you've never tried.
That would be pretty funny!
Not for me. She'd be impressed that I'd finally run the dishwasher myself, then enraged when she opened it up and the only thing that came out was the body of an H5.
