2 minutes ago, Fourmi Kill3r said:
Hello!
So i have a 144hz monitor.
In rainbow six siege, with vsync on, it is stuck at 60hz and i can't change it. Is it a normal thing or no?
Don't use v-sync? V-sync will increase latency and isnt really needed
My GTX 970 carries me to global.
https://linustechtips.com/topic/588760-144hz-stuck-at-60hz/#findComment-7667204
3 minutes ago, Fourmi Kill3r said:
with vsync on
vsync limits your framerate to 60 or 30. just turn it off
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/588760-144hz-stuck-at-60hz/#findComment-7667209
