Hi everyone
I've been looking at vesa mounts for a triple monitor setup. I have two 23.8" 16:9 monitors that I want to put on either side of a 27" 16:9 monitor. The issue I am having is finding a vesa mount that supports this setup. All the vesa mounts I can find only support three 24" monitors. I'm not sure if they will support the 27" being in the middle and still have the side monitors angled towards me for a more surround setup. If anyone knows of a mount that works like this, please link it to me.
Thanks for all the help!
https://linustechtips.com/topic/587954-the-hunt-for-27-triple-monitor-vesa-mount/
1 minute ago, Theburninbeaver said:
Hi everyone
Why not have three separate display arms?
Sig under construction.
Do you mean something like this?
http://www.newegg.com/Product/Product.aspx?Item=9SIA3BG16H8959&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Accessories+-+Monitors-_-9SIA3BG16H8959&gclid=Cj0KEQjwo_y4BRD0nMnfoqqnxtEBEiQAWdA128eKpt_6tUUWW9hy826YL9jmifvNy-RcUYaUmZN8CRwaAu9i8P8HAQ&gclsrc=aw.ds
then yes, I would love to have three separate arms. But you can see on the page that it only supports three 24" monitors. Which I don't know if they support that one 27"
1 minute ago, josephaltareb said:
I did see that one but it doesn't allow you to angle the side monitors towards your face, which is what I would like.
Thanks though!
