Dual Monitor Help
Solved by Rolling Potatoe,
yes, right click on the desktop, click displays or some such.
YOu should see display 1 and 2, you can just drag the one you want on the left to the left and it will be on the left.
Luka_664 ·
Posted in Troubleshooting0 -
6
3
corodedotter93 ·
Posted in New Builds and Planning1 -
2
MimoAW ·
Posted in Troubleshooting7 -
4
1
Ancient-Act6477 ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
This solves the Raspberry Pi’s BIGGEST problem - Pineboards POE+
