Physics question: More energy to bike or walk?
Simple question, When biking or walking to a location and back, which one takes more energy from the person doing the action? My friend says that you have to use the same energy because you go the same distance, but I think that you loose less energy biking because the tires are more efficient.
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/587242-physics-question-more-energy-to-bike-or-walk/
I think it depends on a few factors one is what is the bike made of  eg is it a carbon fiber super light one or is it  made out of steel and really heavy and are you going up a hill.  From personal experience taking a 10 speed steel bike up a steep hill take a lot more energy than it does to walk it up, but if it is a really light bike it will take less.  Plus the tire width comes into account, there are fat tire bikes that are used by year rounders (winter bikers) that have more friction because of pavement contact, and then the racing bikes like Tour de France  that have very little tire on the pavement.  When I switched my primary bike to one made of aluminum instead of my steel bike it became a lot easier for me to hit higher speeds because of less weight required eg flat ground top speed 20MPH on the Steel bike vs 30 MPH on the aluminum bike).  Also gearing matters as well
I think that primary thing you have to take into account is the gear system on a bike, a single rotation of the pedals gets you a circumference of the tire of ride distance, that's why bikes have such huge tires. On a typical 26" tire that's 2,07 m. Try doing that much in a single step!
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
Walking gives you a more diffuse effort on the body than it does while biking. It then depends on the efficiency of the muscles involved.
In terms of energy there are no ways of knowing besides experimenting, too much parameters involved. You'd have to study the energy chain and see which one has the best efficiency per meter traveled and height climbed.
Well we can at least take into account that humans are about 25% efficient but like your stating, there's too many variables at play to be clear.
Bikes are much more efficient.
On a bike you spend less energy maintaining balance
When you walk waste lot of energy moving your entire body up and down
When you lift your foot to take a step all the energy spent lifting it is wasted whereas when you're biking energy from a lifted foot is translated into forward motion
Bikes allow you to recover stored kinetic and potential energy allowing coasting
