Noise isolating Blue Tooth Headphone under $500
I am first time shopper for expensive high quality headphones, before this the most I spent on headphones were $10.
I am looking for a new set to update my swag however I also want nice quality aswell, my friend told me however to stay away from beats at all costs.
Here are my preference in order :
1.Aesthetics
2.Blue Tooth
3.Noise Isolation
preferably under $500
I would imagine the Sennheiser Momentum 2.0 wireless tick every single box you have.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
Looks awesome,  anything more aesthetic?
Also whats the built-quality and approximate durability?
For the sennheiser
1.Aesthetics
2.Blue Tooth
3.Noise Isolation
Look at some options from Sennheiser. The Momentums or Urbanites are your best bets.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
