I currently have a problem that I have no idea what to do to try to fix it. When I was playing games suddenly when I alt tab both of my monitors started going crazy. one screen was flashing white and the other one was a solid gray color. When I restarted my computer i was sitting with a gray screen on one monitor and the other one was also gray. After i unplugged on of my monitors from my graphics card then the monitor that was plugged in was working fine. Right when I plug in the 2nd monitor though everything went back to a solid color for both monitors... Any ideas for fixes?
GPU: Evga GTX 750TI FTW
https://linustechtips.com/topic/586393-dual-monitor-help/
almost certainly a gpu issue
that monitor problem can be caused by a faulty gpu
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/586393-dual-monitor-help/#findComment-7641729
Are you using a 364.xx driver? If so, downgrade (say, 362.00 or 361.xx)and try again; plenty of reports of dual monitor setups acting weird with those last few driver releases.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/586393-dual-monitor-help/#findComment-7641739
