Anyone have a good experience with a company that makes monitor tree's? I want to get three of the 35 inch curved benq 144hz monitors and set them up on said tree. I have not done a multi monitor setup before so I am not 100% on what to look out for. Thanks in advance if your awesome enough to lend me a hand.
https://linustechtips.com/topic/586037-multi-monitor-stand/
most of the tripple monitor arm are expensive like this http://www.amazon.com/Mount--MI-4PC313S-Adjustable-Articulating-Compatible/dp/B00KIXTYHY/ref=sr_1_13?ie=UTF8&qid=1461396059&sr=8-13&keywords=freedom+monitor+arm so i would recomend this http://www.amazon.com/Mount--MI-753-Computer-Monitors-Compatible/dp/B00BDT072S/ref=sr_1_15?ie=UTF8&qid=1461396059&sr=8-15&keywords=freedom+monitor+arm because even i will be using this in my build
and if possible i would recomend not wasting your money on this stand and just using the stock stands.
my build http://pcpartpicker.com/p/Zs8bnQ
https://linustechtips.com/topic/586037-multi-monitor-stand/#findComment-7638324
