The R7 370 is about ~35% above the 750 Ti but also costs more
https://linustechtips.com/topic/585797-need-help-about-gtx750ti/#findComment-7636275
Just now, JorelCedrick said:
how about the 360?
Around the same or maybe a bit under. Can't remember
https://linustechtips.com/topic/585797-need-help-about-gtx750ti/#findComment-7636307
Just now, aSPIRIn4 said:
750 ti is a very good buget card
For 768p yes. For 1080p not anymore
https://linustechtips.com/topic/585797-need-help-about-gtx750ti/#findComment-7636324
It can handle , but not at max settings and other stufs
Nah, it's to the point where new games run at 30-40fps on low. 950/370 minimum these days for 1080p
https://linustechtips.com/topic/585797-need-help-about-gtx750ti/#findComment-7636344
