Hello my Fellow Geeks and Nerds " does any use that saying anymore ?"
I have an awesome Swiftech H240-X and i would like to know if you can change the loops ? I have had a look around but no joy ! could someone with more knowledge than the likes of I be of help please !
Thanks
Jimmy
Thanks
Jimmy
Welcome to the Forums!
For the tubing they use a 3/8ID 5/8"OD tube so you will want to source the same dimension of tube. They are held in place with tubing clamps which unbolt allowing you to remove the tubing, I would recommend draining the fluid partially or as much as possible first before doing this to not make a mess.
  • 1 year later...
On 22/04/2016 at 9:11 PM, Guest said:
Be careful my friend, Its a slippery slope, I started with that mod on my h240x, then a new cpu block, then another rad, lol 700 bucks later the h240x isn't even installed anymore
hahahah yeah... i'll give it ago ! thanks for the heads up tho !
Thanks for the help and sorry for the delay ! i put this on hold till now ^_^
