So his budget is ~$600-$700 but he can go lower if needed. He is not looking to play any games so I don't think a GPU is needed. That said he will mostly use this for 3D modeling/rendering but I'm still not sure if he needs a GPU. He plans to use probably only 1 monitor, but I'm not sure and neither is he so I'll just update this as needed. Below is a probable build that I thought of on the fly so feel free to make suggestions.
PCPartPicker part list: http://pcpartpicker.com/p/qgqpxr
Price breakdown by merchant: http://pcpartpicker.com/p/qgqpxr/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ SuperBiiz)
Memory: G.Skill Aegis 16GB (1 x 16GB) DDR4-2133 Memory  ($61.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($64.99 @ Newegg)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($76.99 @ Newegg)
Case: NZXT Source 220 ATX Mid Tower Case  ($48.99 @ SuperBiiz)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($45.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.89 @ OutletPC)
Total: $554.82
Generated by PCPartPicker 2016-04-20 00:30 EDT-0400
Note:  He also doesn't need the hyperthreading (I think, do you need it for this type of work?) and overclocking features of "K" series CPU's hence my choice.
Note 2: I'm aware that there's no OS or peripherals, which is why the price is what it is and gave his budget some headroom.
https://linustechtips.com/topic/584561-building-a-workstation-pc-for-a-friend/
3D rendering definitely needs a GPU, that is why most rendering workstations cost a lot, because workstation GPU's like the AMD firepro or the Nvidia Quadro cards cost a lot. 3D rendering is also more RAM intensive so the higher amount of ram possible to get, the better. I would suggest taking a look at http://www.tomshardware.com/answers/id-2844283/gpu-cpu-modeling-rendering-video.html
That
link should give you some idea of what different purpose computers need.
Good luck on the build mate
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
That
man I was hoping to make this a budget one. thanks for the info though mate.
That
so I just did a brief skim through the thread and I just remembered that my friend is using AutoCad for architectural work. What should be the build now? The link you gave me is about a person who seems to be into game modelling.
I would suggest getting a secondhand Firepro card and if there is going to be any hardcore modelling go for 23GB RAM
@rice guru
here's a pretty decent build
PCPartPicker part list: http://pcpartpicker.com/p/jmK3zy
Price breakdown by merchant: http://pcpartpicker.com/p/jmK3zy/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($69.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($32.99 @ SuperBiiz)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($72.33 @ OutletPC)
Video Card: Asus GeForce GTX 950 2GB Video Card  ($127.99 @ Micro Center)
Case: Corsair 200R ATX Mid Tower Case  ($44.99 @ Micro Center)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $667.16
Generated by PCPartPicker 2016-04-20 01:22 EDT-0400
4 core 8 thread cpu, a fairly decent gpu,
the only downside is no SSD, would get a 250gb one in the near future or if you can stretch the budget
edit:
managed to fit an ssd in :I
PCPartPicker part list: http://pcpartpicker.com/p/yXNPyc
Price breakdown by merchant: http://pcpartpicker.com/p/yXNPyc/by_merchant/
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.77 @ OutletPC)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($58.99 @ B&H)
Total: $708.59
Generated by PCPartPicker 2016-04-20 01:26 EDT-0400
but if you want 16gb of ram
PCPartPicker part list: http://pcpartpicker.com/p/Kpp2K8
Price breakdown by merchant: http://pcpartpicker.com/p/Kpp2K8/by_merchant/
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1600 Memory  ($58.99 @ Newegg)
Total: $649.60
Generated by PCPartPicker 2016-04-20 01:27 EDT-0400
feel free to add an ssd but it would be overbudget
-sigh- feeling like I'm being too negative lately
  Hide contents
Total: $667.16
edit:
  Hide contents
Total: $708.59
  Hide contents
Total: $649.60
so I don't need a professional grade GPU like the one The Flying Sloth suggested?
it highly depends on what you're rendering
what softwares are you using? will it benefit from CUDA or OpenGL?
Total: $554.82
so , here are the minimum pc specs that is required mid range 3d rendering and modeling , yeah I have crossed the budget but you get more bang for the buck
PCPartPicker part list: http://pcpartpicker.com/p/yqy4FT
Price breakdown by merchant: http://pcpartpicker.com/p/yqy4FT/by_merchant/
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($60.88 @ OutletPC)
Memory: Mushkin Essentials 16GB (2 x 8GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Storage: Silicon Power S60 120GB 2.5" Solid State Drive  ($36.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ Amazon)
Video Card: AMD FirePro W5100 4GB Video Card  ($323.99 @ SuperBiiz)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($22.99 @ Micro Center)
Power Supply: EVGA 400W ATX Power Supply  ($19.99 @ Amazon)
Total: $798.81
Generated by PCPartPicker 2016-04-20 01:44 EDT-0400
The build suggested by Aditya is what I was getting at. if your friend can afford it go for it, if not do a 775-771 conversion and stick in an older Xeon, buld the rest around that. Good luck with the build.
@rice guru
