http://www.amazon.com/Elgato-superior-technology-hardware-encoding/dp/B014MQIVPS/ref=sr_1_3?s=pc&ie=UTF8&qid=1460860419&sr=1-3&keywords=elgato+game+capture+hd
So I want to buy this for my pc but my new gpu blocks it from being installed. Is there a way to wire rout the slot out of pc so I can use It. Also is there a external case I could put it in? I know they make things like this for gpu's to use on laptops but didn't know of it would work for this situation.
[ PC SPECS ]
GPU----> ASUS STRIX GTX960 4 GB DDR5 OC
CPU----> AMD FX-6300 6-Core
RAM----> (SET OF 2) Crucial Ballistix Sport 4GB Single DDR3
MOBO---> Gigabyte GA-78LMT-USB3
HDD----> Western Digital Blue 1 TB WD10EZEX
CASE---> Rosewill Dual Fans MicroATX Mini Tower Computer Case
PSU----> Rosewill 450W power supply
Also, any opinions on how I can better improve my current pc Config would be great too. xD
https://linustechtips.com/topic/582977-best-way-to-use-a-elgato-hd60-pro-pcie/
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
why don't you get a regular HD60?
