Budget and location?
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/582662-build-for-a-friend/#findComment-7605314
4 minutes ago, experiencednoob said:
Theres no budget but would prefer it cheaper.
From philippines
...still doesn't answer the question...some people may think $500 is okay to be spent on a computer while other may think $1.5k is alright so...budget?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/582662-build-for-a-friend/#findComment-7605374
From philippines
get a 390 then
cpu good, just get a decent psu when u buy
(also from the phillipines, some they recommend you to buy a crap psu... )
PC SPECS :
cpu: intel i3-6100 @ 3.70 Ghz (stock) gpu: Sapphire Nitro OC R9 380 4GB motherboard: Gigabyte H110M-DS2-CF
Case: NZXT S340 (glossy black) Memory: G.Skill Ripjaws DDR4 @ 2133 Mhz Storage: WD 1TB hard drive PSU: Seasonic S12II 520W
° ͜ʖ ͡°)  o baby yis....
https://linustechtips.com/topic/582662-build-for-a-friend/#findComment-7605397
Items not linked are from
http://services.pcgilmore.com.ph/pricelist
cpu: intel i5 6400 PHP 9050
mobo:msi b150m pro vdh PHP 5460
graphics card: msi r9 280 gaming PHP 9900
ram:kingston hyperx fury black 8gb PHP 1800
Ssd:kingston hyperx fury 120gb PHP 2600
hdd:toshiba 1tb PHP 2300
psu:fsp raider 550w silver 80+ PHP 2995
case:tecware raiden elite PHP 1400
total:PHP 35505 (768.506USD)
if you need OS, get it from kinguin/reddit windows marketplace for around $20-30 USD.
https://linustechtips.com/topic/582662-build-for-a-friend/#findComment-7605537
