Corsair AX760 cables compatible with Corsair AX860
Go to solution Solved by colinreay,
Yes they are, check this.
Yes, they are compatible. If they were not, then Corsair would not sell the Type-3 pinout individually sleeved kit and the 24-pin for them.
http://www.corsair.com/en-us/professional-individually-sleeved-dc-cable-kit-type-3-generation-2-black
http://www.corsair.com/en-us/individually-sleeved-ax-860-760-atx-24pin-generation-2-blue
3 minutes ago, Bartmole said:
Pretty sure they are, just double checking, thanks. Friend says no, other site show yes.
Yes the units have the same backplane or pinout design, it's mainly the wattage that is the difference for higher loads.
