Hey guys, I need some help choosing parts to build a pc. I'm looking to spend about $1500 usd. I'm really into corsair and nvidia parts so wherever those can be implemented would be great. Going to use it mostly for gaming, CS:GO and several others. Any help would be appreciated.
https://linustechtips.com/topic/580478-need-help-choosing-parts/
Went $30 over and it's very overkill. Also used corsair and nvidia where i could. chose a gigabyte 980 ti instead of evga bc for the price it's the best imo
PCPartPicker part list: http://pcpartpicker.com/p/PWnVt6
Price breakdown by merchant: http://pcpartpicker.com/p/PWnVt6/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($238.99 @ SuperBiiz)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($59.99 @ Amazon)
Motherboard: EVGA Z170 FTW ATX LGA1151 Motherboard  ($189.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($74.99 @ Newegg)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  ($61.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.77 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($638.99 @ SuperBiiz)
Case: Corsair Carbide 400C ATX Mid Tower Case  ($89.99 @ Micro Center)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($129.99 @ B&H)
Total: $1532.69
Generated by PCPartPicker 2016-04-11 20:37 EDT-0400
https://linustechtips.com/topic/580478-need-help-choosing-parts/#findComment-7583288
Here's my recommendation. Not totally Corsair since other brands offer better bang for your buck for certain parts (for instance, the PSU):
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($239.99 @ Newegg)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($94.99 @ Newegg)
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard  ($138.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($64.49 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($87.77 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB ACX 2.0+ Video Card  ($599.99 @ Amazon)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($74.99 @ NCIX US)
Total: $1425.97
Generated by PCPartPicker 2016-04-11 20:44 EDT-0400
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/580478-need-help-choosing-parts/#findComment-7583321
So what's your display set up? Because by going with a 390 you can fit in a 1440p 144hz IPS free-sync display, the G-sync equivalent is $200 more, would be great for CS:GO naturally. Though possibly worth it to get an i5 that can OC and a Z170 board. would mean dropping the SSD though. Otherwise you could drop the display to a 1080p 144hz TN Display that would be easier to run at higher settings, but you'd probably never have to replace the 1440p display below.
PCPartPicker part list: http://pcpartpicker.com/p/xQzcQ7
Price breakdown by merchant: http://pcpartpicker.com/p/xQzcQ7/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ SuperBiiz)
Motherboard: MSI B150M Pro-VD Micro ATX LGA1151 Motherboard  ($59.99 @ Micro Center)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2133 Memory  ($55.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($56.97 @ NCIX US)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($40.98 @ Newegg)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($72.99 @ SuperBiiz)
Monitor: Acer XF270HU 144Hz 27.0" Monitor  ($582.77 @ Amazon)
Total: $1422.44
Generated by PCPartPicker 2016-04-11 20:52 EDT-0400
https://linustechtips.com/topic/580478-need-help-choosing-parts/#findComment-7583350
Included a 75Hz 1440p 1ms monitor, a Corsair Vengeance K65 Compact Mechanical Keyboard, and a Corsair M65 Mouse.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Directron)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($79.99 @ Amazon)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($34.99 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($569.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($55.11 @ Mac Mall)
Power Supply: Antec EarthWatts Green 500W 80+ Bronze Certified ATX Power Supply  ($64.95 @ B&H)
Monitor: Acer K272HUL 75Hz 27.0" Monitor  ($245.98 @ Newegg)
Keyboard: Corsair Vengeance K65 Compact Mechanical Gaming Keyboard Wired Gaming Keyboard  ($89.99 @ Newegg)
Mouse: Corsair M65 Wired Laser Mouse  ($39.99 @ Amazon)
Total: $1557.73
Generated by PCPartPicker 2016-04-11 21:04 EDT-0400
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/580478-need-help-choosing-parts/#findComment-7583387
This is as much Corsair (and Nvidia) I could fit in to your build. :S
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($51.89 @ OutletPC)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory  ($39.99 @ Newegg)
Storage: Corsair Neutron XT 240GB 2.5" Solid State Drive  ($82.98 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0+ Video Card  ($294.99 @ Newegg)
Case: Corsair 350D Window MicroATX Mid Tower Case  ($77.99 @ Amazon)
Power Supply: Corsair RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($105.98 @ Newegg)
Total: $956.57
Generated by PCPartPicker 2016-04-11 21:40 EDT-0400
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/580478-need-help-choosing-parts/#findComment-7583538
