cable extension for motherboard 24 pin, 8 pinCPU and PCI-E
I'm looking for cable extensions to hide the ketchup and mustard look (PSU IS NOT MODULAR). I would prefer black cables. I don't how much they would cost. Can some one tell me the best option. Also the currency that I use will be £.
Thanks. :D
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitor: 24" Acer S240HLBID | OS: Win 10 Pro.
duct tape? thats all i know off to sleave un modular PSUs xD
Builds:
Search for SilverStone SST-PP07-PCIB on Amazon UK (after using the LTT affiliate link). This is the 6+2 PCIE one, but they do all the others also, and they were the cheapest I found. I only got two PCIE ones for my GPU as I hate the cables my PSU came with which has a middle connector also and look ugly.
So... 6 way PCIE cables are £3.29 each (x2 for GPU?), The big and little ones for PSU are £7.51 and £3.29. So the set would be around £20.
As extensions, you would need somewhere to hide the PSU original cables.
Thanks. Would I need 2 for the GPU:
The cables you need depends on what connectors you have and want to replace.
Mobo 4/8 pin power: http://www.amazon.co.uk/SilverStone-SST-PP07-EPS8B-EPS-8pin-ATX-4-4pin_300mm/dp/B00B5VW1NW/ref=pd_bxgy_147_img_3?ie=UTF8&refRID=1EGQ0XX0DYYZ3HD7S6NN
Mobo 24 pin: http://www.amazon.co.uk/SilverStone-SST-PP07-MBB-24pin-MB-24pin_300mm-black/dp/B00B5VXH44/ref=pd_bxgy_147_img_2?ie=UTF8&refRID=12TSFS19EWHJ5GA4J3GP
PCIE 8 pin to 6+2: http://www.amazon.co.uk/SilverStone-SST-PP07-PCIB-PCI-8pin-PCIE-6-2pin_250mm/dp/B00B5VW21S/ref=pd_bxgy_147_img_3?ie=UTF8&refRID=12TSFS19EWHJ5GA4J3GP
PCIE 6 pin to 6 pin: http://www.amazon.co.uk/SilverStone-SST-PP07-IDE6B-PCIE-6pin-PCIE-6pin_250mm-black/dp/B00B69IZVU/ref=pd_sim_147_7?ie=UTF8&dpID=41cILjkVtpL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=12TSFS19EWHJ5GA4J3GP
When I googled the CPU in your sig earlier, it seemed to show two 6 pin PCIE power sockets, so it would be the 4th one on the list above. If I'm mistaken and you need an 8 pin one, it would be 3rd. Obviously you would need to order as many as you need to fit.
1st and 2nd are for power to mobo if you wanted to replace those also.
Looks like the price for one either has changed or I typed it in wrong earlier.
I'll get the 2x 6+2 cables for the GPU in case I want to upgrade my GPU to a new one which might require an 8 pin.
Anyway, Thanks for your help! xD:D
