Building my own 3.5mm cables
UnlimitedTMD
Hey guys,
I`m looking into making my own 3.5mm cable for audio passtrough for all kind of stuff, like my headphones, AMP, DAC, Home Theater Set.
I always just bought some from some stores, but they`re soooo bad, they always break, kink or deform on me.
I`ve been looking at some DIY guides and stuff, but they`re always like, yeah just get some old 3.5mm cable and apply new pluggs.
So they never explain what exact kind of a cable it is... I know I can use Cat5e ones, but I`d rather want more robust cable.
So what cable should I buy?
Maybe you can link an Dutch and/or European link? :)
TL;DR; What cable should I buy for 3,5mm audio passtrough (not Cat5e)?
to game or not to game, that`s the question
use shielded cat5e cable?
What are you looking for?
I`m looking for something more elegant and sturdy, I also would like it to be relatively fancy looking...
6 hours ago, W-L said:
-snip-
Thanks mate :)
But isn`t the second one a XLR type? Isn`t that only for those other plugs or could I use it either way?
5 hours ago, UnlimitedTMD said:
Thanks mate :)
The first one would be the best option, the XLR will work as long as it has the correct number of conductors needed also, it's just physically a larger cable with larger conductors which would be good if your going for very long cable runs.
aaahhh I see, thanks for your replies :)
Any electronics store will have audio-grade cable that is sold by the meter. You need 2-lead pair cables (Left Channel positive and null; Right channel positive and null). On the jack connector you'll have left and right go to their respective solder points and the null cables have a common solder point. If you want I can get a guide rolling later in the week that will show you step by step what you need and how to make your own cables.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Damn  mate, thanks for your answer. If you have the time, please do so, I`d love it :)
I`ve been looking at some stores, but can`t figure it which sort I should get and I don`t know if they`re made for audio..
