What is the output voltage of arduino uno's 9, 10, 11 gpio pins?
Guest
I'm trying to power a RGB Led but it won't even come on so I can only assume I used to much resistance because I didn't know the output voltage. I thought it was 5v but I guess not. So what is the output voltage of arduino uno's 9, 10, 11 gpio pins?
im pretty sure its 5v or 3.3v. depending on which pin you wire to your breadboard.  gpio pins only are for data in my experience correct me if i'm wrong.
It should be 5V.
Edit: There is a pull up resistor for sourcing voltage. This means that it's output has a limited current. The output voltage will also be tied to the supply voltage of the arduino.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
