Use an old receiver as headphone amp ?
Guest Generallee
So, i have this problem with my integrated realtek 7.1 sound card, it is configured as 5.1 in windows audio manager and the realtek audio manager and it works absolutely fine with my basic entry level logitech x530's, however, if i want to use my m40x's i have two choices, either crawl under the desk and plug them directly into one of the free jacks and set it up as "headphones" on the realtek manager, or plug them directly into the headphone port of the x530's. The problem is either way, i can't hear shit, litterally it's like the volume is locked at 30% or something, i pushed every volume slider in windows to the max, nothing, even the knob on the x530's does nothing as i think it goes passtrough. The only way to make them work is crawling under the desk every time and unplugging the x530's three jacks, plugging the headphones, go to audio manager set up to 2.0 and then it sounds normal. My case's front audio is busted so that's out of the equation since it's not even plugged into the mobo. Now, i have a fairly old sony DAV S880 (picture below) that's lying around doing nothing so i thought hey, it has an optical In, the mobo got an optical out, i then connected everything and the m40x's sound of course waaaay better and louder than the mobo's output, i also installed a utility called audioswitch that lets me set up a key to quickly switch between outputs on the fly.
TLDR : headphones too quiet on mobo, no monies to buy dac/amp, mobo + optical out + old sony receiver = dac/amp ?
you can use the headphone out on the amp, often they are amplified as well, although many amps have a high noise floor so that may be noticable.
couldn't you set one of the rear outputs on your mobo as (front) headphone output and gain some volume that way
#killedmywife #howtomakebombs #vgamasterrace
use the headphone out, not speaker out, or you might blow your headphones
Yes of course, i'm using the receivers hp out
Another question i have, on the sticker this thing still got on the front, it says Dolby Digital/DTS, now using windows audio manager when i test Dolby, it works and a little "Dolby" lights up on the receiver, but when testing DTS, nothing
Anybody got a clue ? Is it because of optical ?
this should be fine if your ok with the size of it :)
Builds:
You can try it, but don't be surprised if the noise floor is depressingly high.
I just looked up what noise floor is, i don't really think it is that noticeable at fairly mid volume since i don't want to explode my ears
However i do hear that hiss at super uber high volumes with nothing playing
Unless you have a 'real soundcard' I don't think the optical out is gonna do audio only dts is dvd's or videos encoded. ..
 Don't quote me on it but I'm pretty sure onboard audio won't do it you need to use the headphone out to a 3.5mm stereo rca thing to your receiver input of choiuce
In the Windows Playback devices go under properties (mine says "SPDIF-OUT"), under supported formats make sure DTS Audio is checked, and if it doesn't work under Sample Rates check each rate one at a time.
It's possible your motherboard doesn't support it.  You could try finding a newer driver on the manufacturer's website.
