Is it possible to revive a dead cpu?
Go to solution Solved by Deputy_DDoS,
23 minutes ago, _Chaotic_ said:
A friend gave it to me because it wouldn't post in his board, so I tried it in mine and it wouldn't post. I have fixed dead boards, power supplies, graphics cards, and even hard drives, but I've never fixed a cpu before, so I don't know where to start. Which is why I came on here to see if anyone has any idea.
If only some of the cores are dead you could try disabling them and try and run it with less than 4 cores but if cache or key components are fried unless you have a clean room, an electron microscope, can get a hold of (and understand) the schematics for the i5 4670, have robot arms and are a wizard it's unlikely for anything else to be fixed or worked around
I have a dead intel i5 4670 and I wanted to know if their was some way to revive it, you guys have any ideas?
What killed it? If it was bent pins, then you have a chance.
CPU: Intel i5 3550           | Cooler: Corsair A50          | Motherboard: Asus P8Z77      | Storage: Crucial MX200 250GB |
RAM: Corsair Vengeance 8GB   | GPU: GTX 1650                | Case: NZXT H440 (Red/Black)  | PSU: EVGA 650W G2            |
7 minutes ago, Minzo said:
We can't tell you unless you tell us more about the problem.
Basically, nothing starts when I press the power button, and this cpu was used in 2 completely different systems. Both systems worked with this pentium I recently bought, but not the i5.
Well that pretty much answered my question. Maybe one day, but not today.
