Remote desktop into pc without logging it out over lan
Solved by hambobolubia,
try setting up a VNC server after a quick google i found https://www.realvnc.com/ this may not be the best option but it should work for you i use a linux vnc server to remote in to my raspberry pi. i can even do it from a android phone. good luck
specsdude99 ·
Posted in CPUs, Motherboards, and Memory2 -
1
2
5
1
Tydn12 ·
Posted in New Builds and Planning3 -
2
ID0 ·
Posted in Networking2 -
eviohh ·
Posted in Troubleshooting3 -
5
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
