Search In
  • More options...
Find results that contain...
Find results in...
I think I've gotten two of the worst 970s for overclocking
So I just got a 1440p monitor and finally had a reason to overclock my gpus, but sadly found out that one of them can handle +90mhz and the other can handle only +75 before I have artifacts and blue screens. I'm pretty sure that binned gpu's tend to overclock well but I guess I just have shitty luck. Anyone else have issues with gigabytes g1 gaming line?
GPU - 2x GTX 970 g1 gaming (sli) CPU - I5 4690k 4.6Ghz Cooler - Kraken x61 PSU - Corsair ax760 RAM - 32gb Corsair vengeance pro 2400mhz Storage - 730 Series SSD 240gb Case - Phantek enthoo pro
The card G1 is already overclocked by Gigabytes. +90 is very good if the card already has over +1300-1350 ish.
The G1s are the best 970s..
Looks like you got really unlucky bud.
Best Bench Runs & 24/7 Rig
Best Bench Runs
i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T
24/7 Rig & Clocks
i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda
really? I remember back when I was looking I was seeing people with cards running +1400 but maybe that was just a few lucky scenarios
Not for noise. But they have been known to have GPU that managed to not get binned.
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
My friend could barely get above 1300 with his. It's a silicon lottery again. Don't push it if you're already getting blue screens.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
Not really. The G1 is the best 970 for overclocking.
Why did you have to relate it to noise?
The G1 970 is the highest binned and beefiest 970 besides the HOF (HOF sucks tho)
Best Bench Runs
24/7 Rig & Clocks
I was under the impression the g1s were best clockers, but your clocks seem normal, I hit 1400 ish (prob more like 1450Mhz) on mine before shit hits the fan, I suspect I could hit more if I did a bios update/flash to allow more voltage, as even with afterburner voltage maxed my cards still don't exceed 55C on my loop
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
@Gofspar
Pls halp
Best Bench Runs
24/7 Rig & Clocks
What are they boosting to? At +90 mine are just over 1500mhz
Rig Specs:
AMD Threadripper 4999WX@4.8Ghz
Asus Zenith III Extreme
Sapphire 6900XXXT Quadfire
G.Skill Ripheartout X OC 5000Mhz C12 DDR4 4X8GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Cards equipped with Elpida RAM are notoriously poor overclockers. The ones that came with Samsung chips are a lot more flexible. Even my 66% ASIC Windforce 3X card can hit +200C/+400M without flopping.
Check GPU-Z to see if you have Elpida RAM, it will show you in the Memory Type field. Another good bet is to check with Gigabyte for vBIOS updates. A lot of their GTX 970s have several and they make huge improvements since my card wouldn't even run right at stock without the update. Remember to follow Gigabyte's instructions and make sure you apply the updates to the proper vBIOS chip (there are two) by using the correct DVI port.
The New Monster: Alienware Area 51M R1 / i7 9700K / RTX 2080 / 2x8GB DDR2400 /  x3 1 TB SSDs (x2 NVME M.2 x1 2.5")
The Relic: MSI GT780DXR - i7 2670QM / GTX 570m 1.5GB GTX 970m 3GB (GT72) / 16GB DDR3 1600 / 512GB ADATA SU800 / 2TB SEAGATE SSDHD
SOLD The Laptop: Alienware 15 R3 - i7 7700HQ / GTX 1070 / 16GB DDR 2400 / 256GB M.2 SSD / 512GB M.2 SSD / ADATA SU800 512GB SSD / Killer 1435
The Monster: Athlon XP 2800+ @ 2.3GHz, Asus A7N8X, 2x1GB DDR400, ATi X850 XT AGP, WD 80GB Caviar (PATA), No-Name 700W PSU, Deepcool Tesseract
You can't judge a core by the memory type lol
@boboman342 has a 980 Ti that can do 1560 (maybe higher) yet his memory can only do +200 without training..
Best Bench Runs
24/7 Rig & Clocks
Top card is 1460 bottom is 1300, :^/ seems like they're just average but nothing special
My case fans+a reference GTX 970. And considering my card struggles to overclock as high as a lot of Windforce (non G1 Gaming cards), they are not binned properly.
PMSL
How does any of that relate to this conversation?
I'm confused.
Best Bench Runs
24/7 Rig & Clocks
I'm confused.
GTX 970 G1 Gaming are far from the best.
PMSL
My EVGA GTX 970 SC ACX 2.0 shits itself at anything above a 1367 MHz boost clock (which GPU Boost 2.0 takes to 1418 MHz).
No they aren't lol
They are binned the highest and have some of the best power delivery. @Gofspar
Best Bench Runs
24/7 Rig & Clocks
No they aren't lol
Nope.
PMSL
Just now, Dabombinable said:
Nope.
nice counter argument ;)
Best Bench Runs
24/7 Rig & Clocks
I must be REALLY lucky with one of my MSI 970's I hit 1612 on the core without artifacting or crashing; with my second I got about 1582.
They are not binned the highest, not when you can get a GPU with an ASIC score of 62.9%, which means that it requires a lot more power to reach the same clock speeds as GPU with higher ASIC scores, and runs a lot hotter, 77oC before overclocking on mine with 28oC ambient, excellent airflow and a clean heatsink+fans. Every single GTX 970 Windforce owner that I've seen overclocking has had far higher overclocks on their cards than mine, and to top that all of, with those that show the ASIC score its a lot higher.
Edit: And to top that off, mine on idle is louder than my case fans at 75% and my Seidon 120V's water pump at 100%. With the load noise being audible through out most of the house.
PMSL
Right, because one shit overclocker means the entire manufacturing process is the same..
And ASIC doesn't mean a huge amount with Maxwel.. Maybe Big Maxwell but not Tiny Maxwell
Best Bench Runs
24/7 Rig & Clocks
ASIC has very little impact with the 980Ti as well.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Newegg
