Will a samsung 950 PRO m.2 go in my motherboard
Solved by annoyingmoments,
8 minutes ago, GFXTech said:Will a samsung 950 PRO m.2 512GB SSD go on my Gigabyte Z97X Gaming 7 motherboard?
I have never used m.2 so I don't know anything about it and I just wanted to know if there is a compatibility thing between m.2 and whatever other m.2. Thanks
It should, but have in mind, that the Gigabyte Z97 boards only support speeds up to 10Gb/s= ~1,25 GB/s. I intended to get the 950 Pro too, refer to my signature for my specs, but I am going to use a PCIe expansion card for it. Else I would only use half of the perfomance/speed.
EDIT: As @QBtech wrote, it has something to do with the max supported PCIe lanes supported by the chipset and PCIe version 2.0 vs 3.0.
