Gigabit ethernet over USB 2.0
Solved by BrightCandle,
I don't know if you will get all that close to the theoretical limit of USB 2.0. One of the problems I have seen with high throughput devices on USB is a lot of CPU usage, and its not sounding like the machine this is going into is all that modern and hence fast. You might find the CPU becomes a bottleneck for high throughput on USB 2.0. I don't doubt it'll be faster than 100 mbit/s but 300+ is potentially not the case depending on what peripheral you actually end up buying.
