VB Tie System?
Arcapse
Can someone show me how, on Visual Basic, to code a 'tie system'? I'm working on a program for a competition to determine the winner. It selects the winner by a Find Maximum algorithm using a 1-D array. I'm a fairly novice user of VB.
Cheers & Best Regards,
Arcapse
Use your logic. If Int1 == Int2 Then WinnerText = "Draw" or you can loop throught it and check it, You shouldn't be learning VB, I would recommend Java
I know, right now I have a boolean draw variable. But I don't know how to output multiple winners
Arcapse
Run a loop on the array and get all the winners to another arraylist, output the array in text using a loop
Since you already have the winning score, just loop through all the participants and do something with every user that has that winning score.
1. VB's comparison operand is the same as the assignment - there are no double or triple equals signs.
2. Without knowing the OPs future aims or goals, study/work project undertaken decisions or past background, you would change his career path? That's extremely obnoxious & arrogant to be honest...
@Arcapse: In what format do your results from the array return in if there's (1) 1 winner (2) a tie with 2 winners (3) a tie with 3 winners please? It usually helps if you could post any code you have tried so far - so we can all give advice and tweak that (thereby helping you to learn & understand your code and design choices to improve), rather than writing something from scratch of our own thanks.
1. Sorry, Just use to Java Coding double equals signs.
2. Did you read my second post? Anyways I'm just saying OP should also learn Java
Dim pointsArray[] As Integer =                                 Your 1D array of points dataDim points As Integer = 0Dim numberOfWinners As Integer = 0Dim highestPoint as Integer = 0For i As Integer = 0 to pointsArray.Length() -1   points = pointsArray(i)   If points > highestPoint Then                                New winner      highestPoint = points      numberOfWinners = 1   Else If points = highestPoint Then                          Another winner with same points      numberOfWinners += 1   Else                                                        Not a winner                                                               Do nothing   End IfNextMsgBox("There are " & numberOfWinners & " winner(s) with a score of " & highestPoint & "!")
How about this?
 Almost as cool as my temps
How about this?
Aye, I appreciate you taking the time to write that out for me, greatly appreciated :) But I need it to display the names of the two winners?
Arcapse
Where are the names stored?
Another array? Or is the points array actually 2 dimensional?
(Or do you not know and are asking me?)
Right now, I have it set up in two different sub procedures (necessary) - the first is for finding the winner(s), I have the part working if it's just a single winner. The second sub program is for the display / output using a list box. I unfortunately don't have VB installed on this computer so I'll try manually typing it out or some shit.
draw = false
Sub 1:
For counter = 1 to 5
   If score(counter) > winnerscore Then
      winnerscore = score(counter)
      location = counter
   Else If score(counter) = winnerscore Then
      draw = true
   Else
   End If
Next
Sub 2:
If draw = false Then
lstoutput.items.add("The winner was " & name(location) & " with a score of " & winnerscore)
Else if draw = true Then
lstoutput.items.add()
End If
I don't know how to store and establish these winners, and correctly output them. I need this program finished soon so help would be appreciated
Arcapse
I really need to get this figured out soon, help would be greatly appreciated
Arcapse
What you have looks like it will work. You just need to finish the else block in sub 2 with another loop
draw = false
Sub 1:
      location = counter
      draw = true
   Else
   End If
Next
Sub 2:
    lstoutput.items.add("There was a tie. The winners with a score of " & winnerscore & " are:")
           lstoutput.items.add(name(counter))
       End If
    Next
End If
edit: Also, just a couple notes
If draw = False Then
' is equivalent to
If Not draw Then
' and
If draw = True Then
' is equivalent to
If draw Then
You don't have to do the equality check for the Boolean type. You also don't need an empty else block (like in Sub 1) if you aren't doing anything with it.
draw = false
Sub 1:
      location = counter
      draw = true
   Else
   End If
Next
Sub 2:
       End If
    Next
End If
' is equivalent to
If Not draw Then
' and
If draw = True Then
' is equivalent to
If draw Then
Cheers dude this helps a lot, much love <3
Arcapse
