[Project Lan Syndicate]
godsarmy
Couldn't you fit a 120mm rad at least in the top and bottom of the second pic?
In the back rad chamber the dual 240 rads will be thicker and have fans. The res pump combo will be there too. So there wouldn't be enough room for more rads.
Alright, Maybe put all the storage in that chamber too? Also, will this thread become the main build log thing when you've received the case?
USEFUL LINKS:
PSU Tier List F@H stats
noice idea mate, but I think your not using the space to it`s fullest extend
to game or not to game, that`s the question
I got 2 ssd's in front of main chamber. And yes ill be moving my current build to this case.
(Current rig)
Thanks man! It will be about 13 wide by 13 deep by 13 tall :)
you current rig look baller af tho.. what case is that? scratch build too?
i like this idea definently following this and i'm even early!  :D
Its a custom danger den lan 450. I had them make it big enough for a rad in the front. Then a week later they went out of business. :(
And thanks man. I put a lot of work into it. ;)
What will happen to the Danger Den case if / when you build this. That is a one of a kind case are you sure you want to replace it if that is what your plans are.
Any ways I am interested to see how this turns out.
Edit: holy shit I love black and green builds when they are done right.
Ill keep it and maybe use it with a different computer. Its my main rig and 1 240 rad is not quite good enough to cool a 4970k and a titanz.
The design of the new case came from my current case. Shorted the length and added a rad chamber.
And thanks man! ;)
i like the window top that is going to look sick homes! :)
can't wait tho a month!? D: o'well patience is key i guess
Can I have your old case?
"In the middle of every difficulty lies opportunity."
- Albert Einstein
no it's one of a kind :)  sorry
I'll give you steam keys for it.
- Albert Einstein
Pardon if I'm ignorant now, but what program and/or supplier did you use for the custom designed case?
I used protocase. Same company linus used for his watercooled rack mounted case. Be pre warned its not cheap
Thank you. I even watched that video recently, I should've remembered...
Must say I really like your design with getting 3 separate views of Reservoir, GPU and CPU depending on the side. Mind if I ask what the price of your new fancy cabinet is?
Thanks man ;)
And i dont want to think about it lol. Lets just say a inwin sframe type of price for a basic custom case.
It would of been cheaper if i was better at cad and didnt have to use there techs for the cad drawing.
oh my this is sick!
and way faster of a build log than i thought it would be!
congratulations on the new case man!
oh my this is sick!
thanks man! ya the email said it should be sent on the 2nd from Canada. so i expected a longer wait. now i got to dissemble my current rig and get an idea of what water cooling parts i need :)
