will a Gigabyte GeForce GTX 980 Ti 6GB WINDFORCE 3X fit in a Phanteks Enthoo Primo ATX Full Tower Case?
Solved by BuckGup,
hi i am building a computer and i would like to know if the gtx 980 ti will fit in the case without having to take the hard drive cages out. thanks so much -jack
p.s. here is my pc part picker list :http://pcpartpicker.com/p/KJYtP6
Great case chose. Best case I have ever owned and yes you can put huge cards in this thing. You won't be able to use the wire hider but that is fine
