DVI-D or HDMI for color accuracy
Go to solution Solved by thekeemo,
Color quality is the same
but overall DVI is better
DVI has better colors at 120hz 1080p and 60hz 4k
I'm thinking of getting a new monitor with an IPS display so that I can get better color accuracy than my current TN monitors are capable of.
The monitor I'm getting is a fairly cheap one. Nothing professional.
It has HDMI (unsure of what version) and DVI-D dual link (and vga but I'm assuming it's not better than either of the other two).
Would there be any notable difference in what connector I choose? I do not intend to game on it or anything so the aspects of refresh rates etc is not important to me. This would be purely to get better color in movies or when photoshopping etc (which I mostly do for fun, nothing serious).
Does HDMI carry better "color quality" or is DVI better with this? Basically, if I would benefit in choosing one over the other is what I'm trying to find out.
Thanks
System:
i5 3570k @ 4.4 GHz, MSI Z77A-G43, Dominator Platinum 1600MHz 16GB (2x8GB), EVGA GTX 980ti 6GB, CM HAF XM, Samsung 850 Pro 256GB + Some WD Red HDD, Corsair RM850 80+ Gold, Asus Xonar Essence STX, Windows 10 Pro 64bit
PCPP:
http://pcpartpicker.com/p/znZqcf
https://linustechtips.com/topic/519834-dvi-d-or-hdmi-for-color-accuracy/
Won't they be the same?
Please someone correct me if i'm wrong.
Best Bench Runs & 24/7 Rig
Best Bench Runs
i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T
24/7 Rig & Clocks
i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda
Ok, why's DVI better overall?
System:
PCPP:
It can handle higher refresh rates and resolutions
Oh, ok.
Thanks!
System:
PCPP:
Depends on the version of HDMI ;)
Best Bench Runs
24/7 Rig & Clocks
Please do not spread false information. This is not true. HDMI can handle higher refresh rates, and resolutions than DVI.
DVI can handle 120hz 1080 4k 60hz
HDMI cant it can only do 60hz and 30hz
HDMI cant
HDMI 2.0 can
CPU: Intel Core i7 Extreme Edition 3960X | Motherboard: Intel DX79SR "Stormville" | RAM: 32GB G.SKILL Ripjaws Z Series DDR3 PC3-12800 (4x 8GB) Quad-Channel | GPU: 2x EVGA GTX 970 FTW 4GB in SLI (I have Many other builds plus 100+ Macs (don't judge me)... Many specs are listed on my profile)
[PC#1] Log: [Link] [PC#2] Log: [Link] F@H stats: [Link]
You're contradicting yourself. HDMI 2.0 is HDMI. So is HDMI 1.4, what most graphics cards had before. "HDMI" can refer to any version.
