Need advice with graphics card
joeydutchman
So I'm planning on buying a new graphics card but I'm really unsure about which one I should get.
I'm thinking about getting the GTX 970 because it performs good and it has a good price but if I get the 970 then which one do I get? MSI, ASUS etc.
Thanks,
joey
The one that you like!
And if you really can't decide, EVGA
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Well knowing the rest of your specifications may help.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
I've got nothing but good things to say about EVGA so they have my vote. But I've used MSI in the past and they seemed to be good cards.
I have to jump on the R9 390 bandwagon here. But if you are not getting the 390 any of the brands listed are good. For the 390 stay away from asus or gigabyte
[CPU] i5-650 [GPU] MSI GTX 750 OC [RAM] Generic 6GB [MOBO] MS-7613 [HDD] WD Blue 1TB [PSU] Silverstone Strider Essential 500W [Next build Q1 2016 http://de.pcpartpicker.com/user/Presmo/saved/ ]
Please follow your own topics.
I have an i7 4770k and motherboard that came with my prebuilt pc so I don't know which one it is, if I really have to I'll get another motherboard
As long as the mobo has a PCI-E x16 slot you are fine though I am more or less worried about your Power Supply, do you know what it is? If not can you get a picture? What brand was the pre-built?
All I really know about my power supply that it's 450watt, the brand of the pc itself is: Medion.
It's too dark atm so It would be hard to take a picture, I will post a picture tomorrow when it's daylight
That PSU is poop sorry man is a dual rail and not a good one. I´d recommend an EVGA 650 G2 or so.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
Speaking of someone who owns a 970, tbh I would say keep your extra dollars for a 980 or 980ti. I'm quite disappointed about its performance. In gta 5 with everything in ultra it's barely hitting and staying in the 69fps range, UN arma 3 it gets worse! Sometimes iT drops to freaking 21fps, don't even get me started on borderlands.... Save your dollars, it's worth it.
"Audiophilia... when you start to hear voices in your head."
I think you should just save up and buy 4 tesla K80s for dem frame rates... Jokes aside, get a 390 but if you really do want to avoid AMD then EVGA is the best Nvidia vendor.
Get a better PSU before you blow your PSU and possibly destroying you hardware as well cause that's a piece of Junk :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Thanks,
joey
Don't get a strix or a gaming, they are voltage locked pretty low, MSI seem to be the best for overclocking for 1600mhz.
post-122562-0-86798800-1449749955_thumb.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
Thanks,
joey
1. What's your total budget for this upgrade that you're willing to spend?
2. What resolution is your display(s)?
3. You WILL need a new PSU.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
My total budget is 400$ ( PSU not included because i will sell my 760 and buy a new psu)
Im not planning on playing games at 2k etc. i only play 1080p.
I dont need extremely high fps i just want to play at good framerate and at high settings
I will put all my specs below
Graphics card: Gtx 760
Proccesor: i7 4770k
Motherboard:
Powersupply: https://www.dropbox....135829.jpg?dl=0
RAM: 16gb (2x8)
Display 1: benq xl2411z (144hz)
Display 2: (came with my pc) 60hz
With my gtx 760 i get with gta 5 on high 70-90 fps and arma 3 30-50 fps and i dont think i will be able to afford the 980 but it is sometimes only a 7-10 fps difference and that isnt worth 200$ imo
Which PSU should i get thats cheap and that will work with my specs?
Proccesor: i7 4770k
Motherboard:
RAM: 16gb (2x8)
In that case a GTX 970 or R9 390 will do you quite well for a long time yet.
I would recommend something in the 650w range and with an 80+ gold rating. Semi or fully modular is nice, but not essential. Making sure it's of good quality is most important. The Cooler Master V series and EVGA G2 or GS series are very good. Should be able to get one for about what you might get from selling your 760 (~$120-150). NEVER "cheap out" when it comes to PSUs.
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
^That above^
