Gigabyte WiFi Card Issues
Go to solution Solved by thekeemo,
Windows 10 64bit
press win + x
computer management
device manager
network adapters
right click on it
uninstall
run windows update
OK, so I just built a PC a few days ago and I don't have an Ethernet port near the computer so I got a WiFi card from Gigabyte (gc-wb867d-i). It is a PCIE card and I had issues with it from the get go. At first it wouldn't find any WiFi, so i asked around online and someone told me I installed the wrong driver. So I downloaded the driver they told me to download. So now I can see the WiFi but it won't let me connect to it. I tried looking up online how to properly install this thing but no one has a guide and all I see is that, "It works so great," comments. Any help would be much appreciated.
https://linustechtips.com/topic/519697-gigabyte-wifi-card-issues/
Windows 10 64bit
press win + x
computer management
device manager
network adapters
right click on it
uninstall
run windows update
press win + x
computer management
device manager
network adapters
right click on it
uninstall
run windows update
Ok. Running and restarting now. Will windows install a driver for it? Or will I have to install the driver again once it is done?
windows will install a driver
(should)
(should)
OK, it is done with the updates. I went back to device manager and it installed a driver but now I cant see any WiFi networks. The wireless card, if this is help full at all, is the Intel® Dual Band Wireless -AC 7260. When I click on it to get some info about it, its says under device status "This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful.
I'm pretty sure I installed it correctly into the computer, but now I just noticed something after these updates. Before the updates there was a greed LED saying that the WiFi should be good to go. But now there is no light.
Well damn...
try this
https://downloadcenter.intel.com/product/75440/Intel-Dual-Band-Wireless-N-7260
All these I think are just for the Bluetooth if I am reading correctly and I noticed you typed in Intel® Dual Band Wireless-N 7260 when my thing is Intel® Dual Band Wireless-AC 7260. Does that matter?
I guess it could
Never mind I feel like a complete idiot. The problem was... I was typing my old WiFi password in. hahaha. Not really funny tho since this took me hours to realize.
I... I cant even.
  • 2 years later...
There are probably rules here about bumping old threads, but this is one of the top results when searching "Gigabyte GC-WB867D-I wifi not working" so to help anyone who experiences this issue now, I'm posting how I fixed mine.
Window's troubleshooting gave me an option somewhere along the way to "reset network configuration" which fixed everything right after a restart. Updating Windows (since I now had internet) after that gave me the same issue. But then running through the troubleshoot for that gave me the "drivers still need to be updated" thing and then it fixed everything again.
  • 1 year later...
