Maximum safe voltage for ram on haswell?
I am running a 4790k@4.6ghz on a z97 deluxe with hyper x 1866mhz ram that has a stock voltage of 1.5V. I am wondering what is the max voltage I can feed the ram before I run the risk of damaging the ram sticks and the IMC on the cpu permanently. Would 1.7V be safe? How about 1.75V? I am currently running at 1.7V at 2133mhz and cl11, but have not tried optimising the settings further. So far I have compeleted a run of memtest and have not had any errors or crashes
1.7v is fine 24/7
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Is it? I read some other forum posts online that said that high voltages might cause the premature degradation of the IMC on the cpu. I just hope that the overvolt will not kill the cpu as I am just a student and do not have enough money for a new cpu so I would want to play it safe
