Hi guys, I'm thinking on buying a NAS for around U$S 600. I need it to have 6TB of redundant storage (RAID 1?).
I was thinking on using this hardware:
PCPartPicker part list: http://pcpartpicker.com/p/FsQvP6
Price breakdown by merchant: http://pcpartpicker.com/p/FsQvP6/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.89 @ OutletPC)
Motherboard: Asus Z87-Plus ATX LGA1150 Motherboard  ($96.00 @ NCIX US)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory  ($27.99 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($82.99 @ SuperBiiz)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($34.99 @ Directron)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($47.99 @ Amazon)
Total: $603.82
Generated by PCPartPicker 2016-01-02 18:11 EST-0500
Do you guys know if i would be able to build a RAID array with that motherboard? Something i might consider replacing? Thanks!
Sold my build..
https://linustechtips.com/topic/519072-building-a-nas-for-~600/
I think you should go with the WD Red drives 3tb, at least thats what i did for my NAS. What im running in my nas is
I7 3770K
Asus Z77 sabertooth
2X8GB vengeance ram
4 WD Red drives
600T Case with hotswappable drive bays
AX 860I PSU
I pretty well took high end parts from my old rig. Plus these parts are decent for reliability, if you running 24/7 id go with something better for a PSU and drives..
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/519072-building-a-nas-for-~600/#findComment-6896796
I7 3770K
Asus Z77 sabertooth
2X8GB vengeance ram
4 WD Red drives
AX 860I PSU
Are RAM and processor important for a NAS? You are right about the reliability, i will use a better PSU and drives
Sold my build..
https://linustechtips.com/topic/519072-building-a-nas-for-~600/#findComment-6896814
The PSU is just fine for that build. An AX series PSU is MASSIVE overkill for a NAS.
The drives should definitely be NAS drives, though. WD Reds are a good option.
The RAM and CPU will depend on what you're using the NAS for. If it's strictly just data storage, then you don't need a powerful CPU or that much RAM (unless you're using ZFS with FreeNAS. In which case, you need at least 8GB). If you're going to be running things like a transcoding Plex sever or apps on a FreeNAS system, you're going to need a more powerful CPU and more RAM (8GB minimum for FreeNAS with apps).
https://linustechtips.com/topic/519072-building-a-nas-for-~600/#findComment-6896840
If you want 6TB of redundant storage with 4 3TB drives, I think you are aiming for RAID 10. RAID 10 is only supported on REALLY high end mobos, like the Asus Z170 Deluxe. You need a RAID controller/card for RAID 10 on that.
Most NAS software will use software RAID, rather than hardware RAID, so the board shouldn't matter too much.
https://linustechtips.com/topic/519072-building-a-nas-for-~600/#findComment-6896894
If your using RAID 5 or 6, or 51/50 ect. which need a lot of calculation to build the array, it would be better. As for ram Im using my NAS as a server also so i need the ram.
https://linustechtips.com/topic/519072-building-a-nas-for-~600/#findComment-6896916
