Monitor Cleaning
Go to solution Solved by X1XNobleX1X,
Just looking for the best way to clean my monitors without accidental damage since I heard that Windex can destroy your screen or something lol. So should I use a wet cloth? Cleaner? Any help is appreciated, thanks!
You might have already watched this video, but if not :
Yes, use a micro fibre cloth or a coffee filter with clean water to clean the monitor.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/518865-monitor-cleaning/#findComment-6894615
Microfibre cloth and clean water is the way I always do it.
Other systems I've built:
https://linustechtips.com/topic/518865-monitor-cleaning/#findComment-6894623
