New Hyper 212 90+ min temps Help!
Hey everyone, so i bought a Hyper 212 evo for my ASUS P8P67 LE (REV 3.0) LGA 1155 Intel Motherboard replacing my stock cooler from my Intel 2500k I am not and have not run over clocks on this cpu. During the install it took some figuring out but i now have it going but my temps are not normal, i have check bios and things looks normal and i have also re-seated the cpu 3 times now, no apparent change in temps from the re-seating. I have looked at the cpu fan and it appears to be working doesn't seem like alot of power its pushing but in bios i saw it around 800 rpm. any help would be greatly appreciated i will post some pics for info and visual. I am able to play a game such as League of legends i have also notice that the cpu is getting throttled which is normal but just thought i would add, no crashes or restarts have happened.
You're using F is the problem, you genuinely scared me into thinking you had 90C+ temps.
90F is about 32C, so you should be fine.
