Rainbow 6 Siege disply problem
Zentorno56
Whenever I get on Rainbow Six Siege and start playing, it makes the display super weird and distorted and if I go to a certain place I can see these flat trees, gravestones, and other objects. Please help.
Can you post a screen shot of the issue along with your pc's specs and current video card driver #.
Yeah I'll be doing that right now.
What settings are you trying to play the game on?
That's artifacting btw.
http://imgur.com/gallery/cpf7YhE/new
Specs
FX 6300
R7 250X
8Gb RAM
Radeon Crimson Edition 15.12
re-install drivers
set the speeds to stock.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
re-install drivers
This may help but usually when I see artifacts like this it's VRAM related. High voltage or high temps could be a factor.
All low.
re-install drivers
I've never changed the speeds but Ill try reinstalling.
Yeah I only have 2 gb of VRAM on my 250X.
yea reinstall your drivers mate
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
2GB is the perfect. Mostly your drivers. Just reinstall them and see if your problem persists. Does it do this to any other games you have?
I had this during beta i just updated my drivers and it worked fine after
Alright
how much vram are you taking up?
Old Rig
No it's never happened but I think I have to update my drivers.
